My Twin Scroll Custom Manifold
louiswun
Hand made twin gated twin scroll custom manifold for CA18,
How much are you willing to pay for it ?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Thats really nice. What flange is on there?
I would guess if you found the right buyer you could get quite a bit for it. Unfortunately in the CA18 world it can be hard to fund that kind of buyer. Maybe try the 200sx owners club in Europe (sxoc.com) and ask something like £500 or €600?
louiswun
It is T3 divided flange.
I'm not selling mine.
It is US$700 shipped.
float_6969
IMHO, that's cheap for piece like that. I was thinking more like $1000-$1200 USD.
Does it work on LHD?
louiswun
not sure ...ha ha :laugh:
Sideways s12
Car: 84 turbo s12
why wouldn't it work on LHD?
themadscientist
steering shaft on the same side as the exhaust set. It's workable with the stock stuff, but you start running big manifold tubes and wastegates in the same space you are going to need to fold time and space.
float_6969
WELLLLLLL coming from a guy running an HKS T4 flanged manifold on a LHD car when the manifold was designed for RHD, I can tell you it makes a HUGE difference.
I had to grind the top of the wastegate off because it rubbed on the knuckle for the steering shaft and COMPLETELY REMOVE my brake booster because it wouldn't clear the brake master and there was no room between the turbo outlet and the brake booster for a downpipe.
So it makes a BIG difference.
louiswun
float_6969 wrote:WELLLLLLL coming from a guy running an HKS T4 flanged manifold on a LHD car when the manifold was designed for RHD, I can tell you it makes a HUGE difference.
Could you send photos with different angles ?
themadscientist
louiswun wrote:Could you send photos with different angles ?
Be sure to look back over your shoulder and snarl like a dragon in the pics too.
float_6969
This is what it looked like when I first put it together. I was trying to use a hydro-boost hydraulic brake booster from a GM. I built a custom extension to place the brake master where it sits. It worked, but the clearance between the extension and the turbo was too close and the turbo would hit the extension and make a TERRIBLE racket. I HAD to remove it. It wasn't tolerable.
Here you can see how close the downpipe is to the firewall and that the wastegate actuator sits right about the steering knuckle
My first attempt at no brake booster at all. I've since modified this again so it fits/works better.
This is how it sits currently. I'm still not happy with the brakes. They're WAY too stiff to do any kind of "spirited" driving with.
louiswun
Is the manifold design for LHD, turbo placement is more forward and towards the left front light ?
float_6969
No, that manifold is designed for RHD. Hence me having to do all of the work to the braking system to get it to fit. With the stock brake booster and brake master, you can't even bolt the turbo to the manifold. It hits the brake master. If you remove the brake master and bolt the turbo on, there is only about 3" between the back of the turbo and the face of the brake booster. I don't have any pictures showing that.
Volks1470
Car: 1988 Nissan Silvia K's CA18DET
Is this still availible? I might be interested.
louiswun
Volks1470 wrote:Is this still availible? I might be interested.
It is custom made by order and need to wait for about 3 to 4 weeks.
Volks1470
Cool, can you provide some contact info? I'll probably order one of these.
float_6969
Is your car RHD? This probably won't work on a LHD car.
Volks1470
float_6969 wrote:Is your car RHD? This probably won't work on a LHD car.
Yep, i've read through the thread before posting. I've got a S13 Silvia with a CA18DET that's stock. I found a CA18 engine here locally and I'm wanting to build up. I wasn't going to consider the CA till I found this twin scroll manifold. Originally I was thinking of a SR with the Full Race twin scroll kit but sticking with the CA is going to save me a lot of money.
Pretty crazy MC work to get it to work on a LHD...glad I have a RHD.
Edit: So apparently I can't PM until some sort of quota is met...OP, can you provide some email or something in the mean time?
float_6969
Yea, you have to have a minimum number of posts before you can PM. It's to keep the spammers from blowing up ppls inboxes.
louiswun
Volks1470 wrote:Cool, can you provide some contact info? I'll probably order one of these.
louiswun at hot mail dot com
Volks1470
Thanks! Email sent.
