DevilMB3017 »
https://forums.nicoclub.com/devilmb3017-u47101.html
Mon Sep 22, 2008 5:13 am
Cliff Notes At Bottom:
So after fixing so many issues plaguing my car for so long, I was finally able to start driving it a lot recently. I drove it to work (50 miles round trip) four times last week to see how well it was holding up. Some minor adjustments to things like the fuel pressure and double checking all kinds of things all the time led me to be very, very happy with the way the car was running.
And then came a dyno-day on Sunday. I was so excited to see how much horsepower my car was really making. It's on a DynaPack dyno, so I knew not to expect crazy numbers. My car peaks at about 17 pounds of boost on the dyno. The most it's ever hit. The dyno read out 257 rwhp.
Luckily we had the consult port hooked up to a laptop the entire time. My TPS died. Knock sensor fault code. The timing was pulled back like crazy after about 4,000 RPM. So all in all I was upset that I only hit 257rwhp, but amazed I did that with the timing going all over the place and with no TPS and a bad knock sensor. I'm hoping to fix both of those problems and call this one a mulligan and try again.
And then I see some coolant. One of my hoses is leaking by the clamp. A teeny tiny pin hole were coolant was coming out in a stream. Great. Easy to fix, but annoying none the less. One less hose in the way of the knock sensor process though, right?
And then the car dies on the way home. I only live about 5-10 miles from where the Dyno Day was being held. Check fuses. Fuel pump fuse has popped. Replace. Go about 100 yards. Fuse pops. F-bomb. After probably an hour of messing with and testing the relays, fuel pump, fuses, etc., we said screw it and limp home with the fuel pump connected directly to the battery.
Cliff Notes1) Car drives fine 200 miles during week2) Dyno comes, TPS and knock sensor die3) Lay down 257rwhp with no TPS and knock sensor code4) Coolant hose is no good5) Stuck on side of road with no fuel pump6) Limp home with fuel pump directly connected to the battery
