Leo1998 »
https://forums.nicoclub.com/leo1998-u231230.html
Sun May 04, 2014 7:32 pm
I have been reading and trying to figure out on my own but now i need help. What the rig is doing is when i decelerate to slow to a stop and sit at a light the engine wants to die, it will drop to almost 0 rpm then I put my foot on the brake and rev the engine while holding the brake so it doesn't die. I can get it to even out after a few seconds of revving and then it will idle by itself. No problems that i can feel when in motion, only at stops. Sometimes before i take off it drops really low and then chugs forward and catches, then goes fine until it wants to act up again. So far i have taken the IACV off, cleaned and tested it by plugging back in and turning the ignition on and i can see the plunger move. I tested with OHM meter and was 0.00, I cleaned the throttle body, replaced the PCV valve while i had the intake off. I did spark plugs, wires, cap, rotor, oil, oil filter, air filter, fuel filter a couple months ago and has been running fine. The current problem is frustrating because i went to AutoZone and there was 0 codes. Could it be a distributor trying to fail? TPS?
Thanks, i need some ideas or experience with this issue, please. I try to help as much as possible on the forum and now i guess it's my time...crap!
