my turbo upgrade
WeldingHank
Car: 1989 240sx CA18DET
pictured here.
S14 T28BBMegan Racing 3" dump tubeSSAutochrome tubular exhaust manifoldNismo Adjustable FPRFuel Pressure gaugeOil pressure gaugewater temp gaugeFC 550cc Injectors
not shown.
Z32 MAF
originalsin
looks good, this upgrade from the stock ca turbo?
8ggalant
Car: nissan cefiro
i like it hank...i cant w8 to see those numbers...thats the exact setup i plan to run..
float_6969
Hank, where did you get that inlet fitting for the turbo. I need one BADLY!!! Email me about it please! [email protected]
WeldingHank
it came with the turbo. it looks like a custom piece.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
float_6969 wrote:Hank, where did you get that inlet fitting for the turbo. I need one BADLY!!! Email me about it please! [email protected]
use the inlet of the turbo to make a template. Then use some 1/4" thick mild steel stock and cut out a flange. Get a piece of 2 1/4" piping or whatever it is and have a small 2-3" section welded onto the flange. Should have an inlet adapter for just under $20. ...this is worst case scenario of course if you can't find one
vis213
http://www.atpturbo.com/Mercha...e=FLAthat should work, using it on my SR T25 and fits perfect
jjwilks240
Car: cars
are those the ac autotech gagues you have there?
