Aaron_9349 »
https://forums.nicoclub.com/aaron-9349-u14669.html
Wed Mar 17, 2004 11:17 am
An air fuel computer wouldn't hurt, especially since your running stock injectors. Its not necessary though. The EGT is very important though, pretty much shows you when your engines gonna pop. Oil lines are a must, if your turbo didn't have them with the kit, your turbo's not gonna last too long (hell even the vw 1.8t with the little **** turbo has oil lines). Not being mean, just your tubo loves oil. A turbo timer to go with wouldn't hurt either... but staying in your car to cool it (the turbo)down isn't too bad. The guages aren't the end of the world if you don't have them right away... but you should get them soon, especially if you plan more boost. Like _ my greddy turbo kit doesn't come with any guages, but it does come with an air fuel computer (emanage), and oil lines. Also bigger injectors. And that pushes 6.5 psi without an intercooler (although i'm adding the intercooler) So, if greddy puts that in the kit as base items, odds are its a good idea to have them. The injectors are 370cc, and a good upgrade from the stock. You can find those off a 300zx. Oil lines, you'll have to rig that yourself. And the Apexi AFC 2 is a great way to adjust the air fuel setup, and help you run that turbo nicely. Hope this helps ya.
