I'm Rob from Manitoba Canada and I own a JDM 1990 TT 2+0 that was purchased back in summer 2014. I have not been very active on this forum over the years, but would like to provide some progress and pictures on the current build.
Up until last fall, I had enjoyed the Zed will doing some maintenance and exterior updates as I saw fit. I was also slowly purchasing parts for an eventual motor pull. I decided to do that last fall (2021) as the OEM turbos were leaking oil.
Motor was pulled and sent to a local machine shop early winter and I should be getting it back soon. I have been slowly working on it since the spring when time permits. Currently have fitted the intercoolers, reconditioned the headlights/brackets, fitted the oil cooler, cleaned the power steering leak, fixed the front fender pinch welds, painting brackets, and am now re-wrapping the body harness with Tesa 51036 tape.
Here is the mod list for the car:
Rebuilt motor
-stock cams, aftermarket lifters, Z1 springs, titanium retainers, new stock valves, Z1 valve guides, viton seals
-stock crank, Eagle rods, JE pistons, NA oil squirters
-ARP head and main studs
-MLS headgaskets
-BDE motor mounts/alternator mount
-new timing kit with Gates belt
Intake/turbo/exhaust
-JWT Sport 530BB, Ash Spec exhaust manifolds, Specialty Z 3" downpipes, 3" test pipes, 3" B&B quad oval tip exhaust
-Specialty Z intercoolers with 2.5" piping, SZ 2.5" inlet piping with Selin translator
Misc
-Nismo oil cooler
-Wiring Specialties engine/trans harness
-rebuilt brake booster, new OEM brake master cylinder, OEM clutch/slave cylinder (secondary bleeder delete)
-'98 Jspec trans, JWT HD clutch and flywheel, 350z clutch fork upgrade/pivot ball, BDE trans mount
-NA power steering pump conversion, HICAS delete
-replace all coolant/vacuum hoses with silicone
-replacing bolts to stainless fasteners in the engine bay
-lots of cleaning
Thanks for reading. I will update as I can to keep everyone updated.
