My trunk will not open.
Yes I've checked the valet button in the glove box, I even bought a new actuator and replaced the old one. Weeks before it stopped working I would often close the trunk, it would beep several times then reopen on its own. One day I opened the trunk, closed it, returned at few minutes later and it wouldn't open with the key fob nor the inside trunk release. When I press either button there is no sound whatsoever. I've been opening my trunk with the safety release through the back seat.
I saw a couple of post on the board saying they had the same problem and it ended up being a broken wire, but neither indicated exactly where this broken wire was.
I have a 2009 Maxima SV. Is there a fuse or relay to check before tearing my trunk apart? Any other suggestions?
