My truck started smelling like that old p.o.s. in front of you,(gas smell) help?
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
heywier427
Car: 91 Q45
1985 720 z24.
engine has been well taken care of.
143,xxx
under hard accelleration i get that head ache giving gas smell. i have the haynes manual, and checked as many things as it told me to check. and as we speak i have my brother, (mechanic) going over it.
i had the same year toyota, with the same problem, and it turned out to be a vacuum fuel diafram. but i dont see anything like that with this engine.
any help or comments are appreciated.
thanks.
PEZi
i can't really help ya too much on this cause mine smells god awful... i have no emissions equipment whatsoever and the people behind me can't be happy because just idling at lights its noxious enough for me to worry about my health... once i get going i'm sure the people behind me get some big doses of it
but... i'd say it has to be a fuel component of some sort... whether its in the lines or the emissions controls... its gota be there
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
any visible signs around the carb. A lot of time its the float chamber leaking or your setting is too rich. hows your fuel consumption?
heywier427
Car: 91 Q45
fuel is in normal range. and no signs of leaking or anything else around the carb. i checked all the evap and vacuum hoses with no sign of gas smell. oh well guess i gotta just cover up the holes in the floor, so the smell stays out of the cab! thanks.
dogred
Car: 1983 D720
You moght need a new fuel air mixture silenoid. They are pricey, about $150 new.
heywier427
Car: 91 Q45
then i guess ill use silicone around the patches!
Return to “Datsun 720”
