Sleepy_Steve wrote:but that makes little sense as the load should (i think) simply be transfered from the belt to the alternator??
you're right, assuming it's running all the time. actually it's a higher load since you are transfering mechanical energy to electricity back to mechanical, with losses at each transfer. but if you wire it to come on only when the car gets too hot then it will help. when you are cruising down the highway, a fan isn't going to add much airflow. only when you are sitting in traffic will it be necessary, assuming your car is mostly stock.
Sleepy_Steve wrote: ways to tell if the cams have been compromised.
if it's still shiny and not scored, it's fine. i don't know if it's the right one or not.
