My transmission problem
AsanBBoy
This all started when I let someone i didn't know drive my car. :(
the 4 bolts that bolt the flywheel and torque converter together somehow came lose and it scraped the flywheel and the bolts became deformend, 1 missing; any one know what kind of bolts I need or where i can get them? I asume I also need a new flywheel, correct?
When my car was running my, shift alinement was off. Minus well fix it now. I start it in park, fine. I reverse fully in between P and R. In R it is neutral. In N is drive. Can't move to D unless I yank the shifter to D from N. I can get to 1 and 2 if I do the same thing to get to D then press the button and move to 1 or 2, but I have to hold it there (Doesn't lock there). I had it in the normal position (P is park, R is revers, N is neutral ect) , but it wouldn't start in park. My dad did play with the black shifter thing (dunno what it's call, sorry) maybe that's the problem, I dunno. Any sugestions?
