Eswift »
https://forums.nicoclub.com/eswift-u367.html
Tue Nov 26, 2002 12:00 pm
viscosity doesnt necessarily depend on density, but a low fluid level will do that to you. is your car already apart over at atomic? call infiniti of lisle and see how many hours of labor to replace a transmission, and how much the part (the transmission is). Only you can say how much the extra warranties are worth to you, but i would tend to say that the transmission job should come with its own warranty of no charge. (that is, if the shop has any pride in its work, or credibility) I personally have never been to Atomic, I have just passed it driving every day of my life. find out what they are doing for 1500 dollars to your transmission. I personally would have my transmission be the last thing for some unfamiliar tech to pull apart and gauge wear on every piece.
listen to this. you obviously drove the car to atomic. if it is still driveable and not in pieces, fill up the fluid and try driving it, just to be sure it isnt something simple.
my transmission cooler hose popped off in traffic and i lost 3/4 of my transmission fluid in about 25 seconds. it was so bad that the car couldnt even grip in 1st gear (torque converter was starved of fluid) i simply stopped the car (coasted) into the nearest parking lot and filled it up, it works like a charm. (of course this was short term, but it would be worth at least checking out for you)
it would also be worth checking the transmission error codes after filling the fluid, to see if the problem is at all electrically related. it could be in some sort of safe mode.
so, before you lay down any money, do all this:
check transmission fluid level:do this with the car on. note smell, colour, and if there are particlesif it is low, fill it on up.
check for error codes:park vehicle on flat surfaceturn ignition to off*accmove lever to driveturn ignition to on (engine does not start)AT lamp should come on for about 2 seconds hereshift into 3press accelerator to the floor and releaseshift to 2shift to 1press accelerator to floor and releasenow it will flash the code at you:
there should be 1 longer starting signal, and then a series of 11 shorter flashes.
if any of those 11 shorter flashes are longer than the rest, take note of which flash number it is.
these codes start on page AT 36 of the service manualor ask me to find out what it is
thats my reccomendation
good luck
