As of yesterday, my car started acting up. Its an 01 Pathfinder/Qx4 2wd auto with the Vq35de motor
I already had code P0335 (crank position sensor) and I had just removed/cleaned it and orderred that sensor locally. But yesterday, I noticed my car wasnt shifting properly, on regular aceleration the car will shift into second smooth, but as soon as it goes to shift into 3rd..... transmission slips like a motha, revs up like crazy, sometimes shifts, sometimes the rpms just stay @ around 3k and that becomes its cruising rpm.... its like no power is getting to the transmission/wheels.
When cruising maintaining the speed limit, it stays @ 3k and when you push the gas the rpms rise but the car BARELY accelerates.
I checked the transmission fluid level in the dark, and it seemed fine, but Ill confirm in the morning when its cold and on level surface.
So I put the scanner on it. P0774 Shift Solenoid E Intermittent
I have the FSM, but cannot find it anywhere in the damn thing. Can anyone point it out to me. Basically I have no idea whats going on here, and I think I may have to borrow my parents car to get to work tomorrow since I work 40 minutes away and give them cab money since there local....
I made a video of the problem and its uploading onto you tube right now, shows the problem much better than I can explain, heres the youtube vid, processing or some bs, Ill try imageshack
http://www.youtube.com/watch?v=3kTOMtans1I
Any help appreciated
Modified by longhornsqx4 at 10:41 PM 5/4/2009
