My tires are being eaten
Wan
What can I adjust in my suspension setup to stop my tire from rubbing the inside of my wheel well. The outer part of my tires rub this part of the well on both sides. It's eating up my tires. Any help? pics of what to adjust would help. I'm a suspension newbie lol.
Gryphon
Car: '91 240sx
First of all, you need to hammer that ridge flat.Also if you haven't, hammer the inner lip flat too.
Then see if you still rub.
car nut
Car: GT500.
Roll and pull with some negative camber.
93sivliaUsdm
Car: 1993 240sx coupe sold
1990 240sx hatch DE swap
i beat the thing in wheel well in with a hammer on mine, and rolled my fenders no more rubbing
Nesquick
Car: Rb26 Kouki Silvia
smaller tires.......
Dazzla
put the liner back on :p
Wan
I beat the heck out of the liner thing and it helped a little maybe I need to grind it down a bit. Is it my caster that can be adjusted to fix it tho? Maybe an alignment. The car does pull a little to the right lol
