[GoaTSLonG] wrote:right now i have an 89 coupe with an sr20det and a HUD cluster, the speedometer works and the tach is off by 1000rpms
You need to swap in a 91+ Hud cluster, this will work, that's what I did. Or You need just the tach from a 91+ hud cluster and swap it into your '89 hud cluster, this should work, but I haven't tried it. Or you need a tach from a 91+ regular cluster, and swap it into your '89 hud cluster. This might work, if the tach is the same size, again, I've never tried this.
-Martin.
