elvis240sx »
https://forums.nicoclub.com/elvis240sx-u1160.html
Thu Nov 02, 2006 10:11 am
Ok, so here is a little background on the car. My first 240 was about 5 years ago, pignose s13 that was lowered on eibach sportlines with oem replacement struts when i bought it at age 16. the car rusted out and I bought a new s13.
this s13, same year 90 pignose. the suspension is currently all stock. I swapped in a redtop sr with front mount, 3inch exhaust, fuel pump, boost controller and all the other necessities. I have already upgraded the brakes to 300zx TT calipers w/ brembo crossdrilled/ slotted rotors and stainless braided lines on the front. I am running the stock teardrop wheels and had to space them 5mm to make it fit. I dont plan to buy new wheels anytime soon since I just put a nice set of tires on the stockers.
i run the car as a daily driver (except winter) and take it to the drag strip maybe once or twice a year. (13.4 @ 104 is my best time to date). I dont plan to run autocross or anything except for maybe once to see what it is like.
I want the car to be lower for performance and looks but i dont need it dumped to the ground so i rip off my front lip and dent my oil pan everytime i pull into a parking lot. I want to be able to set my alignment to stock specs so that Im not chewing up tires.
so here is what I am planning on buying:
Energy suspension master bushing setSPL subframe bushing collarsTein S -techsKYB GR2Megan adjustable RUCASSuspension techniques sway barsDC Sports solid carbon strut tower bars front and rearSpec EZ front camber kit
As far as the RUCAS go, yes they are cheap. that is why i am planning on those. What I really want are those bushings for the control arms that are offset so you can adjust alignment that way, but for some reason i cant find them anymore. anyone ever seen these?
Also, the front camber kit is a bolt with the lobe on it. is this safe? it is from Enjukus website. I also like the camber plates that SPL offers but would those work with kybs and just aftermarket springs? it says it fits most coilovers but anyone have any experience with them? I like the height adjustability of them, I figure this way I can have a softer spring but still lower it or raise it a little if I dont like the stance.
I am going to be tearing the suspension down this winter while the car is off the road and doing everything all at the same time. I would appreciate any criticism that you have to offer. which springs would you recommend for me? and how about the parts for alignment adjustment? I hope I gave enough information, let me know what you think! thanks
edit: forgot to mention I am not using power steering. and i like it that way
