I just installed ebay's rotors and pads so far so good, but they didnt last long 11 months. Thats my 2nd set since i bough this car 2,5 years ago. However i would go for themKoMikeey wrote:Hey guys my rotors are warped like hell.
heard ebay drilled and slotted arent that bad, but other people are telling me not to do it. and go stock again.
what you guys recommend.
GQM45s wrote:Not sure how much are the ebay rotors you are looking for but have you check FCPimports? They have really good parts and a fairly good price. I found some for you for a reasonable price if you want to take a look at.
PS there is a coupon code "10off99" takes 10 bucks off but hell anything you can get right?
http://www.fcpimport.com/Infiniti-parts/M45/Brakes/
so, basically at the carwash, you run the risk of warping your rotors??atlM35 wrote:Another thing to consider is that rotors tend to warp when you wash the car immediately after driving.
You'll find some kids these days who say that warping rotors is a myth and that it's just uneven deposits of brake dust
It just depends... how hard you were braking before you got there, how much time you had for the brakes to cool down, the temperature of the water, etc.bejjutsu wrote:so, basically at the carwash, you run the risk of warping your rotors??atlM35 wrote:Another thing to consider is that rotors tend to warp when you wash the car immediately after driving.
Yeah, good point. I think I figured out how to eliminate deposits sort of intuitively by braking firmly, but still, pulsation occurs every few weeks. Probably need to have a new set of rotors and pads installed.It just depends... how hard you were braking before you got there, how much time you had for the brakes to cool down, the temperature of the water, etc.
I'm not saying that brake deposits are impossible, I'm just saying that it's not the ONLY cause of brake pulsation.
If you want to eliminate the possibility of brake deposits, just do several hard 60-20mph stops without actually coming to a complete stop... then drive carefully for another 20 minutes to let the brakes cool and then park the car to let it cool down all the way. If the brakes are still pulsing the next time you drive, it's not brake deposits, it's warped rotors... or worn suspension parts
Another good point, one shop torqued down my wheels so tight that I had to use a 3ft. pry bar to take off the rotors.LVdennis wrote:I really believe most problems with warping come when rotating or changing tires. It is vitally important to torque the wheels accurately. Follow the tightening pattern and do not over tighten any of the nuts.
mexillis wrote:Go stock if you want them to warp again down the road. I haven't seen anyone report negative feedback on the eBay stuff.
How do you drive your car?... But they are still not great. I warped my rotors from ebay after a few months, but I warped another set I had before this one in only 3 weeks, and I warped the OEM ones that came with the car within 2 days of owning it. There really is very few if any rotors that this car cant destroy in short order.
I think that's overkill. The M35 has one of the best braking distances in its class, and even among most cars...sergio1987 wrote:I dont know how about you guys, but in my opinion brakes is something that you should not cheap out on...
I did a LOT of research lately and decided to purchase DBA 4000 rotors with Hawk HPS brake pads, its a special order so I'm still waiting, but nevertheless it will be arround $1000 CAD installed.
It might be a bit too much, but when the moment comes that you need to brake for a stupid moran that crosses the street on you while going 150 km/h you REALLYYYY want the best brakes...They make the difference between jail or not.
So the question is: To go to jail, or not to go?))
P.S: DBA 4000 are slotted and rated for street racing, which I'm sure "none" of us do, but let's face it, the car is wayyyyy to heavy for the size of the brake system
Like a badassbejjutsu wrote:How do you drive your car?
Nice!EniGmA1987 wrote:Like a badassbejjutsu wrote:How do you drive your car?
bejjutsu wrote:I think that's overkill. The M35 has one of the best braking distances in its class, and even among most cars...sergio1987 wrote:I dont know how about you guys, but in my opinion brakes is something that you should not cheap out on...
