My stock RB25 whp
Neejay
I made 231whp on a dynojet. I have a 3" syko turbo elbow -> 3" SR downpipe -> 3" resonated test pipe -> 3" N1 Duals.
Does that seem about right? Stock boost, smic, apexi power cone filter.
EDIT: I was only running 5psi boost (wastegate hooked directly to intercooler piping, no boost solenoid). I'm running 10psi now I didn't have my boost gauge hooked up yet, so I didn't know it at the time of the dyno.
Modified by Neejay at 7:15 AM 4/20/2009
Cjmartz2k
Car: Hunting for a '89 GTR now
Sounds a *little* low for a dynojet, but about right on a mustang dyno.
Neejay
Cjmartz2k wrote:Sounds a *little* low for a dynojet, but about right on a mustang dyno.
Damn, really? One thing I need to check is my fuel pressure. I really want to get a Power FC but I was told that the base map that comes pre-loaded wasn't one to drive on.
Bah...
black240jl
Car: black 240sx
that does seem about right.., mod it and get more hp
Joe
thats about right for a stock boost RB25.
Cjmartz2k
I see the stock boost thing now. I think I just assume everybody notches it up a little as the first thing they do. Yeah, numbers look normal.
ANVIL
Car: RB25DET S13.5
Neejay wrote:Damn, really? One thing I need to check is my fuel pressure. I really want to get a Power FC but I was told that the base map that comes pre-loaded wasn't one to drive on.
Bah...
my basemap PFC, dynoed 180whp
after it was tuned it did 265 on 12psi, 288 on 14. all on 90 oct
your numbers seem right
meet07
Car: 89 180sx rb25det
remember 30% loss from motor hp. i beat on a cold nite it feels faster. usually when its cold, with exhaust upgrade you get like an extra pound or two. i too say turn the boost up to at least 10psi. 12 if u wanna really hear the 25 wake up. lite weight fly and 6 puck is a must. : )
Neejay
Cool, thanks guys. I just wanted a baseline dyno before I started modding. lol
LOL So he was definitely right. He told me that the baseline map was to "make it driveable to get it tuned"
I'll probably get a RB20 actuator.
Neejay
meet07 wrote:remember 30% loss from motor hp. i beat on a cold nite it feels faster. usually when its cold, with exhaust upgrade you get like an extra pound or two. i too say turn the boost up to at least 10psi. 12 if u wanna really hear the 25 wake up. lite weight fly and 6 puck is a must. : )
I have a competition clutch lightweight flywheel and a competition clutch stage 2 clutch
Cjmartz2k
That's way high on the correction factor. A manual transmission is like 10-15%, and an auto is like 20-25%. Maybe if you had a full time AWD automatic or something like that
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Neo has ~25-30 chp more, so estimate around ~250 whp. ?
Neejay
Bumping it up to inform that I was only at 5psi at the time. I didn't have a boost gauge, and I was running my wastegate directly from the intercooler pipe (5psi without the boost solenoid).
I'm running 10psi now and it is a lot faster. lol
Carl H
ive seen a neo pull around 260whp on stock boost (6ish psi) on a dyno dynamics dyno...sounds like a good start tho!
Neejay
Carl H wrote:ive seen a neo pull around 260whp on stock boost (6ish psi) on a dyno dynamics dyno...sounds like a good start tho!
Thanks man!
8gti9
Car: '91 240sx rb25det, '94 Passat VR6 Wagon, '06 Sentra Spec-V
what do you guys think my hp will be (rough estimate) on my rb25 s2 will be?
mods are:
fmic 3" sr dp3" full cat back exhaust w/o catgreddy intake manifoldfpr boost set @ 11-12psi
Modified by 8gti9 at 10:32 PM 4/20/2009
lucky7
Car: 97 RB25 S14
depending on dyno, i'd estimate 270-290hp.
Tenchuu
Car: 97 240
stock boost:
10 PSI
with a HKS pop filter, 3" outlet pipe back, and a FMIC. 300z na oem clutch too.
Neejay
Tenchuu wrote:stock boost:
10 PSI
Sweet! Thanks a lot for that. We literally have the exact same mods (3" turbo back, Apexi cone filter, FMIC [hooking/fabbing now], 10psi), and I went to a DynoJet and the next one is a Dynojet. So I guess it's safe to say I'd be at least 260 to the wheels if I can't make it to this next dyno day.
Modified by Neejay at 9:43 AM 4/28/2009
Tenchuu
Car: 97 240
note those are all uncorrected numbers.
virus77
Car: 95 S14, 71 240z, 97 e320
Is that on stock ecu, looks crazy lean but I remember my stock sr20 ran retarded lean like that until high rpm... I dont like factory tunes one bit
Tenchuu
Car: 97 240
late reply: was having break/misfire issues so it looked lean. for future searchers:
Now with a HKS filter, HMIC,greedy IM, Q45 MAF lightened flywheel and 6 puck clutch. tuned with Nistune on Z32 ECU, 12PSI stock 10% ethanol gas on a dynocom dyno.
RRRRB
Car: 98 RB powered S14
This was 11psi with a stock s14 exhuast system and no tuning what so ever
had a Cone style filter on it
FMIC and greddy intake manifold
The pull with higher torque was 4th gear the other was 3rd gear
