Drake57 »
https://forums.nicoclub.com/drake57-u87237.html
Tue Jan 29, 2008 4:17 am
and the joystick only causes a relay click sound (on 1992 q45) . The power telescoping adjustment works. I traced the clicking to a black plastic box under the dash labeled "steering controller". With an ohm meter it was easy enough to find the connector contacts that go to the tilt motor, and raise the tilt using a fused jumper and ground wire - the tilt motor works in both directions, and now that I've determined the power/motor connections at strg. cntllr. I can at least determine which relays drive the tilt motor, unsolder and check them, etc., no problem.
Yes, there is a question here: can anyone say what all else this black box does (other than the steering wheel tilt/telescope)? It looks a little too complex just to control steering wheel position.
Thanks, Drake
