BNasty wrote:how much did a setup lik that cost ya (The swap and turbo)... and did u do the work if not whered you get the work done... or any suggestions where i can get somthin lik that done
The build has cost me a lot over the years. The VE swap alone with transmission and stuff was 3k. The turbo was bought at cost when I got my turbo manifold. For the mani/turbo/dp combo I spend around 3k. I did all the motor work myself. Here's what I have.
255 walbro, nismo 740cc injectors, z32 maf, gt3076r .63ar, protech-fabrication shorty manifold, 3" downpipe to 3" VRS stainless exhaust, nismo FPR, SR20VET cams, custom JE 8:5 (VE) pistons, SR16 block and head, ARP head and main studs, Pauter rods machined for GTiR bearings, GTiR oil pump, DE crankshaft main girdle and oil pans,
Deep breath*
P11 transmission modified for cable, Clutch Specialties custom clutch, NX2k brake upgrade, Greddy MSS for cam switchover, Big intercooler, Tial 38mm wastegate, JWT computer set for 9:1 compression, Prothane motor mounts, heat wrapped the DP and secondary, JWT adjustable cam gears, JWT pop charger on there now. There is prob more than I can list here, but it has taken me 2 years to accumulate everything.
Nothing beats a storage unit build. You can see a full montage on my myspace page.
http://www.myspace.com/jeremyv
I dynoed her at 169whp completely stock VE and nailed 268whp on 10psi. I am running lower compression and better cams now. I hope to hit about 350whp on 15psi and 400whp on 20psi.
