MY SR20DET HESITATES WHEN 4000 RPM UPWARDS
glitter180sx
Car: nissan 180sx 1989 with 95 sr20det
Hi i have a 1989 180sx had a ca18det , now i have put in a sr20det black top , i have recently got it registered and taken it for test drive it hesitates when you hit around 4000 rpm and if i put my foot down more to the floor it hesitates more and sometimes it back fires and black smoke comes out .I have changed the spark plugs and gaped them to 0.8mm . when it starts to hesitate it shows on my auto meter gauge its lean . also it has the standard exhaust from the ca18det and the co2 sensor near the catalitic converter is not hooked up someone told me that the sr20det does not use it, the engine is stock the only thing it has is a front mount intercooler and air filter , ill also add i changed all the wiring including dash wiring because i transfered it from the half cut. if i drive the car and not put my foot down more than half way it runs ok but when i put it down past half it hesitates and backfires out of exhaust really loud like gun shot. i really need help to fix this problem any one out there? would be great i would also like to add that i hokked it up to a CONSULT it come up with no DT. cheers
Modified by glitter180sx at 5:31 PM 10/17/2009
ray666
Car: '92 240 sr powered tuned with a neo
i think the plugs are supposed to be gapped at 28 thousandths. how many psi of boost are you running?
my240sexy
Car: nissa 240sx
hey bro im having the exact same problem. just how u explained it. at first it wasnt so bad. but now it backfires, hesistates and boggs like crazy if i go full throttle passed 4000. did u ever figure out the problem?
codyace
Car: S14 w/redtop
Hesitation past 4000 rpm is typically indicative of FAIL SAFE MODE on the ECU
Check:
MAFCoolant Temp SensorCAS
They are the main triggers of this 'get home safe mode' on the ECU
ZOOMIGUEL
Car: 1989 240sx SR20DET
2006 Lexus IS250 AWD
Happened to me with my KA24DE...
IT ended up being the plugs, ( i recommend NGK lasers)
but i would also check the distributor timing if not the dizzy its self.
Do a tune up... then see how it works..
