my sr20det has no spark, HELP!!
-darren-
i used a test light to do some checks.
so far i notice that i'm not getting a signal from the CAS pinouts on the ecu, and i'm not getting any signal from the coil pack(ignitor) pinouts on the ecu.
i am getting a signal at the injector pinouts though.
does anyone have any ideas on what i should do next?? my cas is brand new by the way.
teddy
Car: Saab Turbo and MR2
Borrow someones ignitor if you've got a friend with an sr and test it to see if thats the issue.
bruinbear714
Unless you have an oscilloscope, you won't be able to "see" the CAS signal.
-darren-
bruinbear714 wrote:Unless you have an oscilloscope, you won't be able to "see" the CAS signal.
you most be from california with that dumbass post.
what is up with all of these irrelevent replies on these nissan forums. i swear there's no help on these sites.
but then again every site has there number of no life idiots.
i guess there really only good for selling cars.
mallbor240SR
Car: 240sx 1990
did the engine ever run before?did you test the ignitor chip using a multimeter?
ILikeMy240sx
Car: SR Power
When no spark I would check the following things...
CAS, Coilpacks, Ignitor, ECU and one thing people forget... Wiring that leads to and from the ignitor and the little ground cable on the coilpack harness and just check all the wiring in general for things that could have gotten disconnected.
When I did my swap, I discovered that a mouse chewed through my wiring and took me forever to find out why why why I wasnt getting any spark.
Good luck.
bdrifta
Car: 1992 Nissan 240sx sr20det
Wow...3 posts total, and already making enemies...ur really bright.
I had the same problem, and it was my ignitor chip.
BobWithBoobs
Car: 89 couple with s14 dohc swap.
where is the ignitor chip located? and where is that ifamous ground off the rail?
fregisr
Car: 240sx 1990
bdrifta wrote:Wow...3 posts total, and already making enemies...ur really bright.
I think he is just an idiot and doesn't know what an oscilloscope is
