duffman1278 »
https://forums.nicoclub.com/duffman1278-u61344.html
Mon Aug 24, 2009 11:32 am
Start with the basics and work your way up from there. Verify and replace all vacuum hoses if necessary. Check your IACV, it might be dirty.
Make sure your fuel pressure is up to par and definitely verify your compression. All you need is fuel, spark, and enough compression to run a car, so something in there is missing or going bad.
