yellowcell »
https://forums.nicoclub.com/yellowcell-u25958.html
Tue Jan 15, 2008 3:24 pm
I have a 89 s13 with a blacktop in it now. the wiring was brand spankin new and i wired the thing myself. well it cranks just fine, now the only problem is that it does not start. i checked the fuel pump and it primes the system correctly. the timing is correct and the spark is fine.
so my guess is the injectors. well i took it off and turned it upside down and turned the key and nothing sprays out of them. theres plenty of pressure in the line so it means that there is plenty of fuel. my guess now is that wither the injectors are bad or the wiring going to them is not sending signal.
***My question is: how do you test if the wiring going to the injector is in proper working order( is there anything i could of done to the harness it self to cause this as i only followed exactly what FRsports.com diagram said to do) and could all my injectors be bad?
