my sr wont crank
goj_cloud
okay ill try that but how could the ing switch be bad if it worked with my ka+ all the relays are getting power when the key is on start position. when you mean the spade connector on teh starter do u mean the little prong connector?
Modified by goj_cloud at 1:49 PM 12/4/2006
goj_cloud
another thing what if i hot wired the car like the other poster said, except for a ignition button? or should i keep trying to figure out why it wot crank?
Blown240sx
Car: 1996 240sx
yes I mean the prong on the starter. Probe thw wire that plugs into that prong.
goj_cloud
Blown240sx wrote:yes I mean the prong on the starter. Probe thw wire that plugs into that prong.
yea i probed it, its getting 0 volts, but isnt that a ground wire though?
Blown240sx
Car: 1996 240sx
No its the signal wire that tells the starter to turn over. The starter grounds through the transmission there is no ground wire specificly for the starter. The starter grounds through the transmission and then through the eninge grounds.
Souns as if you have a problem between the ignition switch to the starter. Check the back of the ignition switch on the start signal wire see if it get 12v or close to. If so then you can by pass the system and run a wire from it to the starter prong.
goj_cloud
which wire is the start signal wire, and isnt the ecu warning light supposed to come on when the ignition witch is on position
Modified by goj_cloud at 10:01 PM 12/4/2006
Blown240sx
Car: 1996 240sx
You need to do some look for a FSM. Your asking a lot of questions which can be answered by using the search button.
goj_cloud
sorry man this is just so fustrating, i tried evrything i dunno what else to do man. im seriously about to cry
goj_cloud
i was just about to have a nervous breakdown whne my niebor came and helped me, it was the dumbest thing. all he did was switched some relays over from one fuse box to the other one she cranked and started. ran for about 10 seconds then died, the reason why is because i dont have any rad fluid in her nor do i have all the vaccum hoses connected ill give u an update tomorrow night
240on430
Car: 1993 240SX SE
sounds like the problem my car is having. i just bought a new battery and it didn't crank the second time i tried start car.
im pretty damn sure i need a new starter solenoid b/c it start when i tap the solenoid. i'll come back with an update if anyone cares. i just need to spend about $50 for a new solenoid.
should i get a new starter(car has a new flywheel) or just the solenoid?
Blown240sx
Car: 1996 240sx
KA24E starter parts + SR Starter Head = Perfect Rebuild
240on430
Car: 1993 240SX SE
...put in the rebuilt autolite starter and hasn't failed to crank since. (knocks on wood)
