My SR teardown and damage
thestartingline
Hey guys, I just thought i would post some pics of my teardown as i prepare for my build. I have lurked here for years, but have only recently started posting. I have owned my 1993 FB for almost 7 years, have had an sr for the last 4. A about a month ago i spun a rod bearing and decided to do a complete rebuild. After the rebuild is done, i am going to install the fresh engine into my 93 coupe. Here are some pics from today, damage was way worse then expected.
#4 piston looked fine here is a pic of #3 and bearings.#2 i was sure this was the majority of my problem right here.#1 This is what i saw when i took the rod cap off.
I was hoping the rods were reusable, but i dont know about that one.
Here are a couple pics of the crank, which was also damaged.
The bearings on the caps looked a little worn.
Modified by thestartingline at 10:41 PM 3/28/2009
With the damage to the crank, is it still fixable? WIll it just affect the bearing grade for that rod?
Modified by thestartingline at 11:23 PM 3/28/2009
Modified by thestartingline at 2:09 PM 3/29/2009
Modified by thestartingline at 2:10 PM 3/29/2009
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
were there any signs before it bombed or did it just $hit the bed?? just wondering...those bearings look uber phucked up...did it knock ?? IT ahd to of for a while before it went...just wondering, good luck
pauliedrft
Car: 91 240sx
dude those bearings needed replaced and i agree with the above post .
thestartingline
yes there was a knock only around 2k rpm, We were sure that it was only valve train. It sounded like a collapsed lifter or maybe timing chain. Then it suddenly got really loud, I parked the car after that. I should have just stopped driving it instantly after i heard the knock.
Koshin
what kind of noise at around 2k rpm?? You couldnt tell valvetrain noise between bottom end noise?? get the stethoscope out my man, all you have to do is listen to it...much of that damage could have been avoided...Everyone wonders why SR's get a bad wrap....
Still good luck with the rebuild...If you need anything I can get you parts for them...later on Bud
Koshin
....think about it this way, now for the future you will definately know if you hear bottom end noise and will be able to distinguish in the future...Live and learn...if you dont have an automotive steth, get one...
thestartingline
yes, its definetely a learning experience. A friend of mine listened to it with a stethoscope when it first started knocking, and the sound was the worst from the back of the rocker cover. I convinced myself it wasn't rod knock. I was told that rod knock would have been audible through the entire rpm range. So i drove it for about another week not revving past 2k and then it got real bad. I parked the car then, and started to tear it down.
Will I still be able to reuse my crank? Or should i just find a used one.
thestartingline
We didn't have an automotive stethoscope, just used a cheap medical one. We didn't even bother checking the bottom end, because the noise was worst at the back of the rocker cover.
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
I have a set of rods if you need them one brand new 3 used in good condition...I decided to use eagle rods for my build
thestartingline
240life wrote:I have a set of rods if you need them one brand new 3 used in good condition...I decided to use eagle rods for my build
Thanks for the offer, but this gives me the excuse to get the cp and eagle combo.
240life
thats what i wound up doing...good combo
Koshin
thestartingline wrote:We didn't have an automotive stethoscope, just used a cheap medical one. We didn't even bother checking the bottom end, because the noise was worst at the back of the rocker cover.
that could have been the problem....I listen to mine once a week or so, just to make sure it sounds like its supposed to....a rod knock will make noise thru the enire rev range...
You will still be able to use your crank, its most likely you will have to have the crank machined and polished...this may require you to use oversized bearings depending on the severeity of the scoring to the crank...keep this is mind when ordering your bearings.....
240life wrote:thats what i wound up doing...good combo
word up...
cody180sx
Car: s14 rb25det fully built 550whp coming soon
you won't be able to eyeball if the crank is good are not take it to a machine shop and have them check it then cross reference it to the fsm
dhessian
Car: 240sx
don't waste your money on aftermarket rods and pistons unless you see yourself making more than 400hp in the near future.
duffman1278
Car: 89 240sx Hatch, the wildcats!
that damage is just ugly....
I agree with the post above, get it checked by a machine shop, or if you have the tools and know how, use a micrometer to measure it yourself and see if the crank is within spec.
It doesnt' sound like you know how though so I would highly suggest taking it to the shop.
Also, the possibility of the crank still being in good shape is very unlikely, just by seeing that damage from the pics.
I also agree that you should stick with the oem rods and pistons.
