my sr stalls after every stop or rev after its warm
wildacexxx
Car: 2002 Q45 nav sport
this is getting annoying. heres the details. i dont have a bov so it cant be leaking (im not pushing it since im breaking in clutch). everytime i come to a stop it dies. i sprayed carb cleaner at all the vaccum points and everything and idle didnt change. i might have a small boost leak here
stupid cold pipe keeps popping off if i give it a lil over 50% throttle. anyway do u guys think that thats my problem there. while at idle if i give it very light throttle it stumbles and almost dies before going up to where it should go.
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
that could be it
try tightening the clamp some more? If not maybe take it off and reclamp with a new one so you dont get that gap
boznuttz
Car: MS13
werd, happedn to my brothers car, stupid sylicon fittings
spider_slayer
Car: S14 240SX
S13 240SX
this happens also to people who vent atmosphericly. but you said you don't have a bov...so i'd check your recirculation lines.
drifter_for_life06
Car: Daily: '16 WRX
Exocet
if you mean by "no BOV", that you have the factory one, make sure its circulated or youll have problems such as this, and running rich
wildacexxx
no bov means no bov lol. im not running one at the moment since im waiting for my enjuku pipe to come in for my ssqv. i guess it might be that. the coupling is the stock one but since i have a arc sidemount its moved around a lil.
heres another question. my afc was reading 100.0% throttle all the time all day today. then i moved the wired on the tps a lil and opened and closed the throttle plate a couple of times. then after work i go and check and my throttle on the afc says 0% all the time no matter if im at wot or not. is my tps fukked? im getting weird voltage readings on the afc also
heres a vid of before i moved around the wires and stuff on the tps http://youtube.com/watch?v=t7cn6K3vXGU
karmakaze
Car: 98 240sx SE
wildacexxx wrote:no bov means no bov lol. im not running one at the moment since im waiting for my enjuku pipe to come in for my ssqv. i guess it might be that. the coupling is the stock one but since i have a arc sidemount its moved around a lil.
check your voltages at the TPS. it should be about .4 closed and 4 at WOT.
wildacexxx
karmakaze wrote:check your voltages at the TPS. it should be about .4 closed and 4 at WOT.
how do i do that? volt meter im guessing. this sux
karmakaze
Car: 98 240sx SE
wildacexxx wrote:how do i do that? volt meter im guessing. this sux
yeah, you can get a digital multimeter from radioshack for about 30 bucks.
middle wire is the signal, positive probe goes there. (you can press the probe in through the back of the conector) ground the negative probe the the engine block or the black top wire on the TPS plug.
wildacexxx
key on or off?
wildacexxx
so i go outside and pop the hood. took some soapy water and sprayed it at that part where the pix are. turned on car and manually revved the engine while i had my head stuck all up in there. needless to say i got an eye full of soapy water. the leak there is major, i have to find a way to close that. as for the tps i moved the wires around a lil. got the afc to read all up to .4 something but that was at WOT. when closed the afc was giving me like .1 something. is my afc wired wrong? or is my tps fukked? i know i need a volt meter but give me an educated guess
