S14toRPS13 wrote:This sounds might sound stupid, but it could just be you've gotten too used to the current power you have. I went from 10 psi to 14 psi a few months ago. My car's still running fine, but the extra power doesn't give me the same feeling that I had a few months ago. If you want to be sure, just check all your hoses and make sure everything's tighten down though.
I see what you mean, but I can feel that there is a difference. I used to be able to spin 2nd from a roll, and now I can barely break traction in 2nd.
Also, I was making some WOT runs in 4th tonight and I noticed that the stock BOV sounded like it was continously blowing off, as in "SHHHHHH" for the entire time the throttle was planted to the floor. I think it may be leaking.
I also smelled oil burning off. Not sure if it's one of the seals in the turbo, or the rings. I had a leakdown test done and it came out really good. S14 SR also doesn't have a factory catch-can.
When I reinstalled my intercooler piping, I double and triple checked that everything was tightened down. The piping is a bot ghetto-rigged, so when I upgrade to a different intercooler, I'll be able to start fresh I suppose.
Rough idle is the sign if a vacuum leak? If so, I have one somewhere, but I have no clue...
