AmoebAssassin »
https://forums.nicoclub.com/amoebassassin-u22213.html
Mon Dec 25, 2006 9:36 am
The stock SR lower pipe should work. I ran a KA rad for a short while. For the upper rad pipe, go to a local auto parts store, and get two 90 degree bends, a length of straight sections, two pipe couplers in the proper diameter, and a few hose clamps. put one 90 degree bend on the engine upper coolant neck, and other 90 degree bend on the KA radiator inlet, so that the two outlets/inlets of the 90 degree bends face each other. Use the straight section, couplers, and hose clamps to connect the 90 degree bends to each other.
