Sugar wrote:Check for vacuum leaks, try a new fuel filter. Check your plugs too for discoloration, although I would expect a sparking issue to effect your more at higher RPMS.
RWD_MIKE wrote:is it at certian rpm or does it break up no matter what , also if u go full throttle does it go away in upper rpms? bc at 2200 rpms my car would buck and studder it was bc my tps was out of place (rpm depending on position of tps urs might not be 2200)
If they let us start giving custom titles again, you're getting "The Grave Robber". Either way, it's nice that you're at least reviving threads that never had a conclusion.PhopsonNY wrote:So ... what happened?
Letting us know would help others
