my speedometer is not working!
slidinsidewayz240
Car: 91 240sx ka24de
I just completed a 5 speed swap on my 91 hatch and now my speedometer is not working, someone told me it probably was the vss sensor or wiring but im not sure what that is or where it is located, the only wiring i did on the car was to get it to start.
edmontontom22
Car: 1995 240sx sr20
your speed sensor is at the very back of your transmission on the passenger side, not 100% sure about the ka transmission but i think its the same. it should be a circular knob sticking out held on by 1, 10mm bolt. THe wire coming out of it will go towards the firewall and you can detach this wire about half way where there is a connector. But like i said im not 100% sure about your transmission
mRodiek
Car: Stock Hatch
Problem solved
nismobenzo
Car: 240sx
edmontontom22 wrote: your speed sensor is at the very back of your transmission on the passenger side, not 100% sure about the ka transmission but i think its the same. it should be a circular knob sticking out held on by 1, 10mm bolt. THe wire coming out of it will go towards the firewall and you can detach this wire about half way where there is a connector. But like i said im not 100% sure about your transmission
is that the only reason they dont work?mine works half the time and then just stops showing how fast im going in the middle of driving..bah id just rewire the whole damn thing if i knew how ha lol
danmansil80
Car: 1989 black hatch s13 ka24de rebuilt forged bottom end.
this happend to me and all i did was replace the speedometer gauge... now it works fine
nismobenzo
Car: 240sx
danmansil80 wrote:this happend to me and all i did was replace the speedometer gauge... now it works fine
now i just have to search for a thread that shows how to do that..sweet....
danmansil80
its easy.. just take all the panels down.. then there are two bolts for the steering colum then three for the cluster and then just make sure the miles dont get messed up and ur good to go.
danmansil80
wait did the speedometer work before when it was automatic?? or when you had another transmission
nismobenzo
Car: 240sx
danmansil80 wrote:wait did the speedometer work before when it was automatic?? or when you had another transmission
mine was never converted..just a stock single cam 5 speed and the trip/tach keeps going off and on at random..rpms and temp always workill probably have to see if i can find a "replacement gauge" when i put in this dual cam so i can reset the miles anyways
danmansil80
nismobenzo wrote:mine was never converted..just a stock single cam 5 speed and the trip/tach keeps going off and on at random..rpms and temp always workill probably have to see if i can find a "replacement gauge" when i put in this dual cam so i can reset the miles anyways
idk i would check the vss first and then find a way to check the cluster.. i doubt you would want to buy parts for no reason. im not sure about the specs.. can anyone help?as for "slidingsidewayz240" i did a auto to 5speed swap on mine and that pretty much ruled out the vss for me. because it was doing the same thing with both trannys. so i changed the gauge=problem solved
nismobenzo
Car: 240sx
danmansil80 wrote:idk i would check the vss first and then find a way to check the cluster.. i doubt you would want to buy parts for no reason. im not sure about the specs.. can anyone help?as for "slidingsidewayz240" i did a auto to 5speed swap on mine and that pretty much ruled out the vss for me. because it was doing the same thing with both trannys. so i changed the gauge=problem solved
im a newb at 240s...VVS??
danmansil80
hey i was typing this chet fast. wait never mind i misread the reply.lolVehicle speed sensor.
jeff420
Car: too many to fathom
nismobenzo
Car: 240sx
i love this website..so helpful!even if there are idiots who dissapoint me..but thats life lol
whyteboi
Car: 1993 Nissan 240sx
mine on my 93 (which i completed this weekend) i just plugged into the sensor with the same plug that was used on the auto speed sensor, mine took a bit of pushing to finally get it to click tight but it works just fine, my only prob is the back-up lights, which i think i just need a new sensor for that
jeff420
read the link i posted and you will figure out how to make your reverse lights work.....
