AxiOn419 »
https://forums.nicoclub.com/axion419-u32499.html
Wed Dec 05, 2007 5:43 am
I have drove the car for only about 2 days and maybe put 100ish miles on it.
When installing the driveshaft, there really was no issue. The bolt holes on the hanger that holds the carrier bearing were like a 1/4inch off but that was the only real trouble I had. Which now that you asked, makes me think. On the ABS driveshaft, is the shaft shorter on the front or back portion? Its coming back to me now. I think I had to sort of pull the carrier bearing back in order to get it bolted up, but not by much at all. As I was typing this paragraph it was all coming back to me like a revelation or something, kind of makes sense now.
So, should I even try removing the dust shield or continue to search for an OEM ABS driveshaft which seems almost impossible to find.
I will measure my automatic abs driveshaft and see if the length of the back portion is shorter than the back portion of the m/t shaft. If by chance it is then I will mate them together, but I am not counting on that being the case.
