my setup will meth inj help?
benspearl240sx
Car: 1998 pearl 240sx
i am building my ka-t on a stock block with itp manifold 2.5 rite to a 3 inch downpipe, greddy front mount, tial 38mm wastegate, 555cc inject, greddy bov the one with the purple top, i am going to run either a jwt or calum ecu and a 60-1 with a ar .63 i want to know is it worth getting the meth injec for my car ecpec that i am running stock internals??
480sx
Car: 1996 Pearl White 240sx
Water injection is universal, it helps boosted cars tremendously. Its basically an octane booster, or a detonation suppressor. You can pull more hp out of your motor with a water injection setup, or you can just use it to be extra safe when boosting.
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
^^ Is there any extra tuning required??
480sx
No, there is no extra tuning REQUIRED. You can use water injection simply as a safety blanket for your motor.
However, when using whatever and injecting it into your fuel mix you drop your EGT's and combustion temperatures significantly. This allows you to safely add more boost and more timing which will increase power.
EDIT - Lol i guess i should say LIQUID injection.. dk
Modified by 480sx at 1:21 PM 5/31/2008
WDRacing
Water injection is for queers...
100% Methanol, Ethanol or even Toluene is by far a better fluid for sub injection. The only thing water does better then the above is cool the combustion temps. But when speaking in terms of efficiency, you don't want to cool it off to much. Cooling equals loss of power and it often adds a lag effect to the turbo since the thermal expansion of the exhaust gases is slowed dramatically.
Anyway, sub injection can be used for a couple of things. I always used it when I reached the output potential of the octane/psi threshold. By that I mean I can't effectively add any more boost without detonation or having to retard to much timing.
You can also use it when you max out your injectors. Say you have 370cc injectors and are running 12psi of boost on the low setting. A good methanol injection kit will allow for an additional 8psi or so beyond that because it's reducing combustion temps AND is used as a fuel source. Effectively increasing your fuel flow even though the stock injectors are running at 100% duty cycle. Which is another thing you don't really need to worry about. Most injectors will run at 100% for a long time without any issues and since it's only when you're running the meth injection on high boost, it's not like they're spending a great deal of time maxed out.
There are many many good kits available today. They range from progressive type kits that ramp the fuel flow up and down with boost, down to the single stage on/off type.
I wrote and article on The Basics of Alcohol Injection, it should explain some of the fogginess and help you form some better questions.
I've been developing my own sub injection kits for personal use for a long time. Pretty much nothing I haven't thought of, so I'm sure we can help you out and get you running some big boost
WD
benspearl240sx
ok so i might just have to purchase on of these things rather be safe then sorry
