JayPat83 »
https://forums.nicoclub.com/jaypat83-u8039.html
Sun Jan 23, 2005 1:27 pm
freshley built kade, 9:1 pistons, cometic head gasket, boost engineering manifold, t3/t4e, 38mm wategate with 15 psi spring, 50lbs injectors thru top feed, RB25DET MAF, new 300zx fuel pump, 3.75" exhaust out of my 3" downpipe, custom V-mount setup with a Koyo radiator and 2 electric fans, fidanza 11lbs flywheel, competition stage 4 clutch, no diff. i'll be running 6 psi for the first 1,200 miles just to be safe then we will slowly bring it up to 15. probably change the spring out cause in the end i am looking for 20~25psi
