My setup!
goomba240
Hey just looking for some opinions and what power I should expect to get from this set up.. Im almost done with my shopping list. Any opinions welcome-t3 super sixty(z31) with no shaft play-custom exh. manifold by efpw ind.-custom down pipe by efpw. ind-apex'i S-afc 2-SR 370cc inj.-steel braided oil lines-1g dsm crushed bov-supra side mount mounted kinda like a frount mount-custom IC piping (home depot lol)-3" exhaust
plan on running 7 psi daily then up it as my income increases ARound What kinda power would I be putting out with this setup?? The only other engine mod my car will still have when its turbo'd is a UR ud pulley. Im gonna have to play with my timing a bit I heard it was rule of thumb for .5 for every psi of boost? And what should I set the s-afc on for 370cc injectors?? Any help is appreciated
Ps.. How accurate are G-tech's on horse power?? Like the 130 dollar ones
MarkEmark
Car: fully-built '95 240sx KA-T
Don't go to home depot for your piping--you'll regret it--TRUST me--any coupling that isn't made for high pressure/high heat (silicone) can and WILL fail, and WILL leave you stranded.
G-Techs have far too many variables to accurately measure HP--G TECH takes into account the drag of the car--and gives you grossly underrated power. I only had about 130 hp according to g-tech at 7 psi of boost--the KA24DE had that at the wheels, STOCK (just about). They're accurate for everything else, however.
goomba240
Alright, I already had a better plan for that anyways.. A friend of my dads owns a machine shop and Ill just give him measurements and tell him what I want.. Cuz I can't weld aluminum very well... I was thinking 2.25 for the piping.. Would that be sufficient enough?
goomba240
And another thing my intercooler is polished and I dont want it to be(its gonna be showing threw the front a little and I hate "flashy appeal") so Im gonna spray it flat black so would I have to look out for anything while doing that?
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
goomba240 wrote:A friend of my dads owns a machine shop and Ill just give him measurements and tell him what I want.. Cuz I can't weld aluminum very well
no kidding...people that have been welding for 20+ years still can’t weld aluminum very well
goomba240
I "can" do it It just isnt "pretty" I did the piping on my buddys eg hatch and it turned out alright.. I'd just rather have it done(espescially cuz this guy is doin it for nothing ;)
huguetpj
Car: 93 KAT Coupe
goomba240 wrote:And another thing my intercooler is polished and I dont want it to be(its gonna be showing threw the front a little and I hate "flashy appeal") so Im gonna spray it flat black so would I have to look out for anything while doing that?
This has been discussed before so try searching. From what I can recall the consensus was to use a VERY light spray of paint so not to affect the intercooler's heat transfer properties and thus it's efficiency.
goomba240
Cool thanks man.. Anyone got any info on the S-afc 2 settings for 370cc injectors.. I tried searching ;) but found a few different answers.. Or is this something I should just play around with till its right?
Trppen37
Car: CA18DET
as for the silicone hose conenctors...just get radiator hoses and cut to fit... too late for me as i already bought home depot couplings...
