MY setup(plans) with costs....ack.
Exar-Kun
Car: 2005 350Z
OK, heres the verdict:
Tein RE coilovers: 2200 dollarsNISMO rear sub-frame mounts: 200 dollarsNISMO 2-way mechanichal LSD: 950 dollarsCarbon fiber driveshaft: 900 dollarsSuspension techniques sway bars: 230 dollarsBattle Version rear suspension peices: 750 dollars
total driveline/suspension cost for my car: 5230
ouch. this is gonna suck....but hey, it'll be worth it.Now if I could just get some more money...-chet
240_Keyy
Car: '90 240 Fastback
mmmmmmm battle version rear suspension pieces are good stuff.
Dunno how worth it is is to have a CF driveshaft though.
captain nismo
are the TEIN RE the top of the line ones? That setup looks nice buddy. ;)
lessthanjakejohn
240_Keyy wrote:mmmmmmm battle version rear suspension pieces are good stuff.
why not? carbon fibre is like invincible and light...
That lsd is going to NICE!
:cool:
BadMojo
Car: 2007 Mazdaspeed 3
Exar-Kun wrote:OK, heres the verdict:
Wow...that's pretty impressive. I would have to sell a kidney (possibly not my own) to afford all of that.
I was startin' to freak because the stuff I was lookin' at was adding up to about $1200. I suddenly feel a bit better. ;)
Just out of curiousity, I assume the reason for the carbon fibre driveshaft to is to make the car a bit more light? How much weight does it save you?
Doogz
Car: '89 240sx coupe
I always thought the point of a carbon fiber driveshaft was to aid in acceleration. Of course it will make the car slightly lighter as well.
lessthanjakejohn
add about 35-70 more, you have to do alignment...
240_Keyy
Well the thing I was saying about the carbon driveshaft is why are you doing it? Wouldn't it be cheaper and just as good to get a 1 piece aluminum unit? They only weigh like 10 lbs...
Exar-Kun
Car: 2005 350Z
alluminum twists a little bit over time, and eventually breaks, carbonf fiber has nearly 100% elasticity, so it never stays twiststed, also it weighs about 6lbs for the entire driveshaft.
yeah, its gonna be a fun setup, most of it wil be getting done this summer, I'll be posting pics of installs and things.-chet
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
Let me know when you have the CF driveshaft done and your final costs. I wouldn't mind getting that done as well....I'm running out of things to do to my car. :D
Exar-Kun
Car: 2005 350Z
will do. although Im leaning toward the tein HE, after some consultation with the IMSA racers arounde here. Most seem to think, after hassis lightening, 10kg/mm and 8kg/mm is far too stiff for my car, even for road racing...
either way, Im still getting some nice coilovers, HE or RE, the C/f shaft will be in about 2 months. coilovers are next, because the NISMO diff isn't going to be here(in the US) until mid-may...:( but oh well.I'll keep you posted bro.-chet
Doogz
Can you run the HE's with your wheels exar? Tein says on s13's to run less than 38mm offset on 6.5in rims. That is 4mm less clearence than the stock rims/tires and to attain that in 7.5in rims you'd have to run 25mm offset or less. Which would stick out like a motha.
Exar-Kun
Car: 2005 350Z
it'll clear. I've seen it done :)-chet
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
so u would say that the one piece alum. driveshaft from Enjuku would be a no-go? just curious...man, just think if u could get carbon driveshafts for $500 shipped...mmmmm, yummy!
-Dan
StanBo
Car: 93 Mazda Miata
10 Toyota Tacoma
I didn't see anything on bushings on your list.
I have upgraded some of my parts but my main complaint is my bushings. I see you are picking hardcore parts so maybe a set of pillow bushings should be added to the list.
I saw a set that replaces everything in the rear that went for 700.
-Whoops just read the other thread. Sorry about repeating someone else.
Exar-Kun
Car: 2005 350Z
"maybe a set of pillow bushings should be added to the list"
Most the bushings will be replaced when the battle version parts go in, all that remains after the switch are the sub-frame bushings, and the front lower control arm busshings(which I've already done with NISMO units)
-chet
BadMojo
Exar-Kun wrote:alluminum twists a little bit over time, and eventually breaks, carbonf fiber has nearly 100% elasticity, so it never stays twiststed, also it weighs about 6lbs for the entire driveshaft.
Cool. I just found out that the 350Z has a carbon fiber driveshaft too. Learn something new every day. It's just amazing that the entire thing only weights 6 lbs.
lessthanjakejohn
How much does the stock drive shaft weigh?
StanBo
Car: 93 Mazda Miata
10 Toyota Tacoma
Exar-Kun wrote:"maybe a set of pillow bushings should be added to the list"
-chet
Good point. I get lost with my lists. I have one with arms and with bushings using the stock arms. I get lets say confused every once in a while. HAHHAHA
Exar-Kun
Car: 2005 350Z
rougly 21-22lbs for stock driveshaft. also, 240_keyy's 17x7.5 +40 konigs barely cleared his TEIN HEs, and he used a 5mm spacer for extra room(bringing net offset to 35mm), and mine at 30mm, so I should be fine :D
-chet
midnight brother
Have you thought about the BYP Delrin bushings for $150 instead of the Nismos?
Doogz
Exar-Kun wrote:rougly 21-22lbs for stock driveshaft. also, 240_keyy's 17x7.5 +40 konigs barely cleared his TEIN HEs, and he used a 5mm spacer for extra room(bringing net offset to 35mm), and mine at 30mm, so I should be fine :D
-chet
Yes...i noticed that in his sig and asked him about it and i found it that it would work just fine.
astron
Have you lightened your flywheel yet? Whatchya running for tires? (i'm just curious...i wish i could pay that sort of money for suspension..but..uh...no...looking like 300 dollars for new struts this summer and as many bushings as i can do will be about it, plus some 200 dollar set of tires..grr)
Exar-Kun
Car: 2005 350Z
yeah, I already have a JUN chromoly flywheel and ACT six-puck racing clutch....and a lot of other stuff. I run 225-45-17 Pzero asymetrico tires right now...
Im contemplating either a set of DOT legal competition tires(A023R, pilot sport cup, Pzero corsa) or maybe swapping to a bridgestone S-03 just for kicks sometime, but my Pzeros are great.
-chet
Jean
Car: Wing chun
Hey, Chet, do you still want the S14 gray cloth seats? I have them at mah house still in duluth? email me. [email protected]
mattback
Car: being a big f'ng ricer
Exar-Kun wrote:yeah, I already have a JUN chromoly flywheel and ACT six-puck racing clutch....and a lot of other stuff. I run 225-45-17 Pzero asymetrico tires right now...
-chet
How are you running a jun flywheel on a KA ?
Exar-Kun
Car: 2005 350Z
they made them for the KA...jean, yeah. you've got mail.-chet
mattback
A12/A14 3.9 2001M-N001 3.7 2010M-N001 L18/Z18(T) 4.7 2001M-N002 4.4 2010M-N002 Z18ET 4.9 2001M-N022 4.5 2010M-N022 L20 4.9 2001M-N003 4.4 2010M-N003 U20 5.0 2001M-N004 -.- ----- ----- S20 5.2 2001M-N005 4.7 2010M-N005 MA10ET 4.2 2001M-N006 3.7 2010M-N006 FJ20E 4.9 2001M-N007 4.5 2010M-N007 FJ20ET 5.7 2001M-N008 -.- ----- ----- CA18DE(T) 5.4 2001M-N009 5.2 2010M-N009 SR20DET(PS13/S14) 5.3 2001M-N011 5.0 2010M-N011 SR20DET(S15) 7.3 2001M-N021 7.1 2010M-N021 SR20DET(PULSAR) 5.2 2001M-N010 5.0 2010M-N010 SR20DE(S13) 5.0 2001M-N012 4.7 2010M-N012 SR20DE(S14) 5.2 2001M-N013 -.- ----- ----- SR20DE(PREMERA) 4.7 2001M-N014 4.3 2010M-N014 RB20E(T)225mm 5.3 2001M-N015 5.1 2010M-N015 RB20DET/RB26DETT 250mm 6.1 2001M-N016 5.7 2010M-N016 RB26DETT(BNR34) 8.3 2001M-N025 8.1 2010M-N025 VG30ET 5.9 2001M-N017 -.- ----- ----- VG30DE(Z31) 5.7 2001M-N018 -.- ----- ----- VG30DE(Z32) 6.8 2001M-N019 -.- ----- ----- VG30DETT 6.8 2001M-N020 -.- ----- ----- VQ35DE 6.5 2001M-N026
Which one of those are you running on your KA ?
i'm interested because I have one on my VG, but I would like to run one on a ka also.
Structure240sx
who makes the carbon fiber driveshaft and where did u order it from? i was thinkin about gettin the enjuku aluminum driveshaft in the summer
Exar-Kun
Car: 2005 350Z
I got mine through options auto salon, JUN does not list the KA flywheel anymore. You can e-mail JUN about it. dennis kalaman has one also....its nice, and I probably wont even have to replace it.-chetoh, the driveshaft is custom from advanced composites, if I decide to go that route. I'm kind of waffling between C/f and the alluminum shaft fron enjuku.http://www.acpt.com/index.html
