My Setup, Help or Suggestions?
tracythedrifter
Car: Nissan 240sx LE coupe
What to you think about this setup!!:p
I'm putting a stock SR T25 kit on my 98KA24de in my 93coupe...
*Brand New KA24DE 98s14 ,only 5k on it.... 205 compression on all 4 *T25 stock turbo *Stock SR SMIC with all the piping*370cc stock SR injectors*T25 KA24DET meGan Racing manifold(eBay loll)*Stock SR blow off*Stock SR Elbow and Downpipe*Z32 gas filter*Greedy turbo timer*ECU Tuned here in Montreal at Almasi Tuning(550$ ,very expensive) *Manuel boost controller*KA MAF*JGS oil lines(I guess :p)*meGan Racing 2.5'' cata*The rest,mendral bent 2.5''*Dynomax Ultra-flow muffler 2.5''*Urethane motor mounts *Exedy clutch kit*Short throw shift kit*Electric fan swap*A/C gone!!!*EGR gone!!!*Everything that you don't need gone!!!*HKS air filter*New NGK spark plugs*New NTK/NGK O2 sensor
I have a couple of question also;1)Info on your experience with a KA24DE-T25 if you ever had one loll...
2)How much power am I going to have??
Thanks dudes
Modified by tracythedrifter at 7:34 PM 2/20/2008
Modified by tracythedrifter at 7:40 PM 2/20/2008
Modified by tracythedrifter at 3:11 PM 2/24/2008
tracythedrifter
And I have 205 compression in all 4...
Brand new KA,only 5k on it.
I'm already doing 15.3 on the ¼mile on finish ****ty tires... ALL MOTOR!!!With bolt ons...
So I should get some pretty good results at 10-12 psi...
C-Kwik
What do you plan to use the car for? The set-up will work on a street car with perhaps some casual drag racing, but I wouldn't expect to hit road courses with the combination of the low efficiency (at moderate boost) turbo and smallish intercooler. You'll likely see heat soak within a few laps.
Florida240sx
Too expensive. You could buy my t3/t4 setup then get some injectors and safc and go to the dyno spend one hour and have a nice running with powerGet a t3 setup. for 8psi no real tuning is needed. get an safc and 370 cc injectors. get a revhard mani or a log style.
boznuttz
Car: MS13
JGS for oil lines! Your KA MAF is good to 250 at the wheels.
tracythedrifter
C-Kwik wrote:What do you plan to use the car for? The set-up will work on a street car with perhaps some casual drag racing, but I wouldn't expect to hit road courses with the combination of the low efficiency (at moderate boost) turbo and smallish intercooler. You'll likely see heat soak within a few laps.
It's my daily drive,so that means a little drag every friday at SANAIR,and some street Drifting every day....Not at all for lapping,it's to hard on a car!!!
tracythedrifter
Florida240sx wrote:Too expensive. You could buy my t3/t4 setup then get some injectors and safc and go to the dyno spend one hour and have a nice running with powerGet a t3 setup. for 8psi no real tuning is needed. get an safc and 370 cc injectors. get a revhard mani or a log style.
Naahh,all the SR kit is comming from my friends Silvia,300$ for everything...I've only got to buy the manifold,the oil lines and the Tuning...So it all comes around 1200$ for some good cheap power
tracythedrifter
boznuttz wrote:JGS for oil lines! Your KA MAF is good to 250 at the wheels.
OKAY,I'll check JGS out....Good to know for the MAF,thanks...
WDRacing
Does the ECU just have a generic rom tune done?
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
tracythedrifter
PantherRacer wrote:Tracy, here is the oil line info.zerothread?id=140446http://forums.nicoc ... d?id=96306
Thanks...!!!!
tracythedrifter
WDRacing wrote:Does the ECU just have a generic rom tune done?
Sorry,but I don't know $hit about ECU tuning
I only do mecanic...
tracythedrifter
NICOclub Rule'S
tracythedrifter
Should I buy this oil line kit for T25....http://cgi.ebay.ca/oil-drain-o...wItem
I guess YESS!!!!
tracythedrifter
Anybody
tracythedrifter wrote:Should I buy this oil line kit for T25....http://cgi.ebay.ca/oil-drain-o...wItem
I guess YESS!!!!
tracythedrifter
Alot of people told me that it would build up alot of exhaust tempature!!!
Is this true....????
480sx
Car: 1996 Pearl White 240sx
I kinda thought you were joking on that Ebay oil line kit, if you were serious, you want to stay the hell away from that kit..
What are you talking about? ' Alot of people told me that it would build up alot of exhaust tempature!!! '
Turbos build EGTs like woah.. If thats what you mean, i have had the manifold on my Ka, and SR glow red because of the heat.
tracythedrifter
480sx wrote:I kinda thought you were joking on that Ebay oil line kit, if you were serious, you want to stay the hell away from that kit..
Whats wrong with it???? curious
Florida240sx
As in the kit itself it is fine, but it won't work for a ka. You need one feed line and one return line....
tracythedrifter
Florida240sx wrote:As in the kit itself it is fine, but it won't work for a ka. You need one feed line and one return line....
AAAaaahhhh okayy...Newbie in Turbo's loll
