DevilMB3017 »
https://forums.nicoclub.com/devilmb3017-u47101.html
Wed Apr 28, 2010 9:02 am
It all depends on how fast your going and what situation. If it's just a street car, stock rotors with good pads - Hawk HPS for example - will be plenty. If you're tracking it a lot, you're going to want to look into upgrading to bigger brakes like Z32 (300ZX) fronts.
I have the JGS kit with the older Turbonetics turbo. I love the kit. I also have an Enthalpy tune and I've been very, very happy with both the tune and the customer service I've received from them.
If you're okay with the 8-pounds or so of the wastegate spring pre-installed on the JGS kit at first you won't need a boost controller at all. I'd still get one if you can afford it though.
And like wise, you won't *need* oil/water gauges, etc. A wideband is something you should get 100% though, but those are more money then the others. This is one thing I wouldn't skimp out on, it's really helped me out a lot.
Instead of gauges you might want to look into a Consult Cable. They can show you any stock sensor output and some other stuff, read your codes, etc. like water temp, timing, fuel injector duty cycle, which can prove really really helpful.
