my service light is on, pls. anyone i need some advice?
Nissan 350z / Nissan 370z general community discussion forum
hotsailor
Car: 1994 BMW 530I, 350Z 2007
hello everyone! i just install a fujita dual short ram intake on my Z by the time i turn my car the service light is on. and when i step on the gas seems like there is a engine cut off when i reached 2500 rpm i need some advice? thanks for looking up and best luck and health to you all this year!
xekushnr
Car: '90 Nissan 240SX Hatch
Did you plug the MAFS back in?
hotsailor
xekushnr wrote:Did you plug the MAFS back in?
yes sir ! i put everything back in.
Dattebayo
hotsailor wrote:yes sir ! i put everything back in.
Well, if that were true, your car would run fine. Maybe you did not plug it in well enough or you missed something. Check it again!
BTW, your SN really kills me! lol
hotsailor
Dattebayo wrote:Well, if that were true, your car would run fine. Maybe you did not plug it in well enough or you missed something. Check it again!
thats a good idea! not bad at all.
Dittoz7
Car: 1997 2f0WtY SE!
Make Sure The Intake Doesn't Void Your Warranty...
OriginalWheelman
Car: '15 Ford Focus Electric
Dittoz7 wrote:Make Sure The Intake Doesn't Void Your Warranty...
Aftermarket parts only void the warranty if they are still on the car when it goes back to the dealer
Dittoz7
OriginalWheelman wrote: Aftermarket parts only void the warranty if they are still on the car when it goes back to the dealer
Well Just Remember To Take It Off! Better?
zozoka1212
Car: 08 Infiniti G35x
Did you disconect your battery?
You should take out the mafs and check if you have som oil on them. The Filter comes in oiled already but they put too much on it. Not all the time but it happened before. That can cause malfunction.
Try to reset you ecu. Disconect the battery and press the gas several times and connect your battery back.
It should help.
Agree with the others if you have to take it back to the dealer make sure you put the oem intake back.
zozo
hotsailor
thanks you all for your ideas. i finally fixed my problem, it was the MASS AIR FLOW SENSOR! I put the other one in the wrong direction. everything is good now thank you all once again! more power to this site!
bmike818
Car: 2007 Z
...I love easy fixes
hotsailor
bmike818 wrote: ...I love easy fixes
same here.. that was a good save! i was about to take the car to the tuning shop.. lolz. the car sounds good now and i feel the difference its a lot quicker.
zozoka1212
Glad you are back to the business.
It is weird you can't do that with the stillen. It only fits one way.
zozo
hotsailor
zozoka1212 wrote:Glad you are back to the business.
zozo
i heared stillen is good, fujita was just my first choice. i thought made in japs are better. hang loose !!!!! money is not an object!
NSRsheets
Car: 2009 Nismo 370Z #85,1993 Nissan 240sx RB25DET coupe, 2013 focus
Glad you figured it out. Don't want unessasary charges at a dealership.
misterlv
hey i took my z to pep boys(big mistake) i couldnt figure out why my ac wasnt working. they did some diagnostics on it and now my cars brake and abs light is always on. can i just disconnect my battery and gas a couple of times and it should be fine?
hotsailor
misterlv wrote:hey i took my z to pep boys(big mistake) i couldnt figure out why my ac wasnt working. they did some diagnostics on it and now my cars brake and abs light is always on. can i just disconnect my battery and gas a couple of times and it should be fine?
im not sure if its going to work but give it a try.
TwinCityTech
Car: s14 KOUKI(low n slow) s13 RB20DET(sold)
MAKE SURE U DIDNT INSTALL THE MAF BACKWARDS! Weve seen this in our shop and it took the master tech 3 days to notice it. REDONKULOUS! Good luck!
Return to “350z / 370z Discussion”
