My Self Diag. Result NEED HELP on solution
oxs1
I just did my self diag and i got the codes... first code was 51: injector then i turned the knob back to self diag mode and counter clockwise and i got 55..? Need help with this techs. Thanks in advance.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
51 is injector circuit...
Id assume you have a bad harness.....
oxs1
How do i fix this? Where can i get a good deal on a injector harness? Need some input please.
DAEDALUS
Car: 1990 Infiniti Q45
Could be the harness. The code means that one or more injectors is showing an abnormally high or low resistance. I've seen injectors over 40 ohms that don't throw a code, but if it's completely open it will. A bad harness or injector could cause it. Next step: Ohm the injectors through the harness to determine which injector is giving the fault. If it's one of the injectors accessible with the plenum on, then remove the harness and ohm directly to determine which of the 2 it is. If it's an accessible injector, then you won't have to remove the plenum, but you will pay more for the injector than you would for a harness.
oxs1
I've tried to ohm the injectors from the connectors but i get odd readings. Maybe im not doing it correclty or maybe its the multimeter since is only cost $10. I tired to ohm them under the 20 selector which is the lowest resistant you can check at... Got readings of 2.4 ohms.
DAEDALUS
If they're all low like that then either the tool or the method isn't right. Unlikely to have 8 bad injectors with that value, and totally impossible for a bad harness to decrease resistance of the circuit.
Q45tech
Come on guys read the history in this forum.
The injector code comes from an over rich signal at O2 [where the block learn goes beyond +120% for one or more injectors.........a rudimentary misfire code.
oxs1
I need step by step insturction as i do not know where to start and what exact tools to use.
DAEDALUS
Q45tech wrote:The injector code comes from an over rich signal at O2 [where the block learn goes beyond +120% for one or more injectors.........a rudimentary misfire code.
Wouldn't that be a leaking injector code (45)?
Ox what's your email address?
oxs1
Email address is [email protected]
