ferreed »
https://forums.nicoclub.com/ferreed-u9943.html
Mon Feb 28, 2005 10:47 am
Tipota,It is possible to damage your engine by running it lean (e.g., running on too much air and too little fuel), but if you have catastrophic engine failure with oil all over the place it is much more likely that you threw a rod due to insufficient oil pressure. If you look around your engine and find a rod coming through the block or pan, that is probably what happened.
Damage from running lean is normally not so dramatic, at least on the outside. You can literally melt a hole through a piston or melt/crack valves by running lean, but normally the symptoms are a non-running engine (or a poorly running engine) with no compression on that cylinder. The injector failures I've seen on my wife's 240 have either been electrical faults where the injector isn't firing at all (and the cylinder can't run lean if it isn't getting any fuel) or there's a fuel pressure leak around the seals where fuel is pouring out onto the intake manifold. I guess it is possible that a fuel leak or a clogged injector tip could cause a lean condition, but that doesn't sound like what you are describing. You can test your injector coils with an ohmmeter-- they should read around 14 ohms.
Was it knocking before it died (knocking sounds like someone knocking on your engine block with a hammer, and the knocking should speed up with increased RPMs if it's a rod, may also get louder) or pinging (sounds like someone shaking a can full of marbles, and would probably be most noticeable powering up hills)?
Prop the hood up and take a look around the top of the engine, then crawl underneath with a light and look for damage. If you don't see any damage and it doesn't make the most awful noises you've ever heard when you try to crank it, do a compression test. You may be able to get a loaner compression gauge from your local auto parts stores. Let us know what you find. There are lots of folks here that know a crap-load more than me about the mechanics of these things, but they're going to need to know what the problem is before they can give you any worthwhile advice.
To answer your question, I'm down in northern AL/southern TN and you can get a running 100k or 120k mile engine here for somewhere in the neighborhood of $400 or $500. If they're expensive in your neck of the woods you can always buy one in another state and have it freighted in. car-part.com will let you search local and national salvage yards for an engine.
Good luck, and let us know what you learn about why your engine failed.
