my s14 is shaking and clicking need some answers.
j u ice
Car: 1991 s13
Well ever sense i've had my car it has been shaking at 50 mph to 80 mph and when i would stop, it would make a thud sound on the passenger fromt tire. well i recently had bent my front drivers side rim and replaced it with a 95 altima rim and tire, however the sound noise stll continues and has gotten worse , it sounds like a flat spot but im not quite sure. i'm thinking it may be because i have a stock rim and tire on the driver side and my after market wheel on pass. side. besides aligment issues what else could cause this clicking sound? Also what causes the car to shake at 50+ mph?
Edub1
Car: 89 240sx KA-T
Shaking can be a bad tire, tire out of balance, big puddle of Fix a Flat in the tire. You might also have a blown strut, bad wheel bearing, worn tension rod bushing, bad ball joint, bad tie rod.
Jack it up and shake the wheel - see what you can find. Also, download the FSM.
Charlie240sxt
Car: 95 240sx SE Ka24det!!! 98 audi A4
he forgot brake rotor, but i'm pretty sure it has something to do with that curb?? you might of hit or whatever it was.? jack up the car check it all out pull push things find the lose stuff or the stuff thats just not right
