I don't have near the patience that positrone must have(awesome build thread man). But I have started the removal of the KA engine out of my 1995 240sx 5spd.
I bought the car thinking it was 'blown', and after getting it home I questioned if it was truly bottom end noise(no metal shavings in oil). I took her for a drive one night thinking it either get a lot worse or stay the same . Well I didn't make it home(stupid cops pulling me over for noise..)
The car had a very very bad oil leak, I think it was from an overtightened oil filter(Had to use a screw driver to break it loose). Which probably led to low oil and a spun bear/rod knocking.
Here is some vids when I got the car.
http://www.youtube.com/watch?v=sW2eRgrq ... KFGR-FenX0
Notice how dirty the motor is. I pressured washed it hardcore after removing the rad and fans.. and its still pretty dirty on the bottom half.
Here are some pics from today's work. The top harness is completely disconnected, trying to figure out if I really need to pull it out of the car or not. The radiator/fan/hoses are out. The power steering pump is sitting on the side. Some of the lower harness has been disconnected.I also removed the hood and bumper.
Things left.. remove the rest of the bottom harness connections, unhook the A/C(bad compressor anyway). Drop the driveshaft/transmission and get a hoist.
I think its pretty close to coming out.
