I could use some suggestions as to what is causing my car to drop RPM's all the way down to anywhere from 50 - 250 RPM's after I depress the clutch while the car is in gear and moving. This also happens in neutral when I rev. In both cases, the RPM drops really low and then bounces back up after the car makes a complete stop. However, at times my car will die out because of the low RPM's. The car will start back up each and every time.
So right now I'm just looking for any suggestions on what to check out. I'm thinking dirty air filter or MAF sensor. Any other guesses?
