philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.html
Fri Jun 27, 2008 5:31 am
In humid weather you will get a lot of condensate (water) dripping from the drain tube near the passenger front wheel.
BTW, do you have the selector set to defrost or defrost/heater? In this case the A/C runs automatically even though the A/C light is not on. Nissan has done this on all recent models as the A/C helps dehumidify the air and improve performance of the defrost mode. It's not really explained well in the manual, but it's there. The only way to prevent the A/C from running is to not use defrost or defrost/heating modes. You will notice the A/C light also turn on when you switch from any of the defrost positions. If you do not want A/C, you have the option of turning it off by pressing the A/C button.
