Best time:
Rxn: 0.9498 (yeah I was sleepin at the light) 60': 2.3827 ( 3.5k drop clutch ) 330': 6.7186 1/8 ET: 10.3359 1/8 MPH: 68.06 1000 ET: 13.4451 1000 MPH: N/a 1/4 ET: 16.0889 1/4 MPH: 85.47
I got 122k miles on the motor and it runs good out of the hole but has horrible top end power. Im thinking its the timing, I may have retarded it instead of advancing it. I also am not 100% sure that I have an open differential in the car, which would be geared 4.11 where as the turbo LSD diff is a 3.62 or something along those lines. I played with the fuel pressure and wasnt running consistently enough to tell the difference but I got it set at 40psi idle ... which I believe is stock?
Mods: cams, cold-air intake, FPR, test pipe, muffler
