Chingon »
https://forums.nicoclub.com/chingon-u8507.html
Wed Feb 25, 2004 2:35 pm
To tell you the truth candela...after dissasembling, I deemed a rebuild kit an unecessary expense. I inspected everything and everything was w/in spec. In definition, "rebuilding" means replacing parts which do not pass a certain standard, whether it'd be with good used ones or new parts. All the clips and bolts just needed some tlc, nothing more. And brake pads seemed like a wiser priority in my opinion.
So in retrospec, if you are doing it right w/expenses in mind, I'd say inspect everything, clean it really good, and reassemble. Of course, many may disagree, but most caliper rebuilding sites I searched through agreed w/my decision. Remember that all the shims are stainless steel or zinc coated, and the boots are made w/high temperature silicons.
