agentlank »
https://forums.nicoclub.com/agentlank-u72083.html
Tue Mar 26, 2013 6:33 am
So I'm not new to the forums, as I used to own a s13 hatch which I did a swap for back in 2007. I've since sold and been driving a grocery getter around for the last few years. A good friend of mine is seeling his 92 2+0 z32 to me. It is a 5 speed t-tops NA.
The good is that it is an incredibly clean car about a 5000 dollar paint job on it 7 years ago, all normal maintenance etc. The appearance of the car for having 220k is exceptional.
The bad is that it needs an engine rebuild, I haven't gotten my hands on it yet, but I think it cranks but there isn't compression. I need more info from him on it but I know that it needs a rebuild.
So what is my best option to build a motor, as I don't want to spend a small fortune on the build if I can, cause I'll need turbos, intercoolers, ecu, injectors(possibly), the list goes on and on...
When all said and done I'd like to have a reliable, streetable 400hp car.
Should I build the motor currently in the car? What are the differences between the NA and TT engine itself?
Should I try to source a domestic TT and then rebuild?
I had really good luck with my sr that I bought, but I get the feeling that JDMs aren't suggested for builds. But it looks I can get a JDM for a little over 1000 that will have turbos, ecu, wiring harness, etc.
All suggestions welcome.
