hey there, do you have to drill and tap a hole for another timing belt tensioner and can you leave it? thanks
cdorhout wrote:So I broke a forged piston in late July that ruined my RB25 block. Rather than rebuild another RB25, I decided to build a RB30DET instead. I had a goal to get it running by this last weekend to make a big road rally that we had this weekend and I accomplished that!
Heres a pic of the block after being bored to 86.5mm
Pic of the front of the block after drilling and tapping the second timing belt tensioner location
Pic of the micro polished crank with JUN crank collar installed. This crank ismuch heavier than RB25.
Pic with RB25 OEM oil pump installed
Pic with water pump and second tensioner
I reused my ARP hardware from my RB25 build, and due to the longer stroke the rod bolts came dangerously close to hitting the side of the girdle, so I took Darius' advice and ground them down at an angle.
Pretty pic of new Mahle forged pistons installed (on stock RB30 rods btw)
Block and oil pan painted
I wanted to keep VCT, so I had to drill and tap a hole in the front of the head to supply oil to that galley as the RB30 block doesn't have a oil source in this location like the RB25
Had to plug the hole that orginally supplied oil to VCT, because in the RB30 block there is a water galley below that location.
Beginning the many fittings required to make and external oil supply for the VCT
Cat in a tiny box
Audi 2.3L timing belt installed
VCT oil fitting supplied from my Greddy sandwich plate for my new external air/oil cooler.
Covers back on and crank pulley back on
Had to grind down the power steering bracket that used to bolt to the head, now bolts to the block. Had to grind down roughly 1/2" of material to get all 3 locations flush.
Had to grind some material off the water galley as it wouldn't allow the stock RB25 exhaust manifold to bolt up.
Ready to drop in the car
Pic of motor in the car, sticks up pretty high.
Car back on the ground, first time since July! The hood does close, but I had to trim a very small section out of the hood support structure.
The car started right up! Did an idle learn on the PowerFC and it idled like stock. Car ran perfectly out of the box with 02 feedback turned on (my wideband is set up for stock o2 simulation).The GT3076R spools much quicker and it seems like I'm always in boost. It sounds bad *** now when I take off from every stop sign and my turbo is whining already.
