Sorry I didn't keep up with this so alot is copy and paste from the Vert forum.
Here are some updates on the project
Oil pan needed cutting and weldingI had a friend at work weld it up.
I also sandblasted the rocker covers and repainted them with high heat gloss black paint. Heres pics of what they'll look like on the motor.
I will post more pictures in a few days, they will be mounting the motor in for its final resting place.
Decided to go with GTR 16x8 wheels instead of the 16x6.5 GTS-T wheels.
See the difference!
GTS-T Wheels
GTR Wheels
This is how they will look on the car
Red Volk Lug nuts
Used Nismo Trans mount
Also instead of using the Apexi turbo timer I switched to the HKS Type 1 Turbo TImer
Here are some pictures after the motor was finally locked into the engine bay
Here are some pictures and updates
Here's the Downpipe issue that is being worked out right now I edited the picture to explain but
basiclly the o2 elbow on the front turbo comes out in the middle of the steering shaft (common issue
from what I hear)
Crashed my Crappy Civic I built from back in the army days.
Brand new from Japan, rb25 (non-Neo) Crank pulley
Down side was that it was a 4-8 week wait
Up side New stock part for $100
Last Picture is of the motor, I'll have more pics thursday
Also picked up 88 300zx BMC
Brembo OE S14 Rotors for the S14 Rear brake conversion
Nismo Short shifter for RB25
JUST A WORD OF CAUTION
CHECK YOUR
ECU
make sure the part number matches the motor, someone on here pointed out that my motor
wasn't a R33. (yeah that was my bad)
BUT the ECU that was sent with the engine was a R33 N1 ECU (2371M-24U00) as you can see my motor isn't an N1
if it was I'd be doing a happy little dance in my living room
ha ha ha
SO I researched the best guess ECu for my motor and went with a 23710-05U61 early 93 round-a-bouts
and is being sent to AutoVaughn Performance in Murfreesboro, TN for a NIStune Type-2 package (board install,
cable, software etc..) As soon as I get that in I'll let everyone know how it is. They also told me they have a R33 block,
Crank, etc all togeather not stripped yet that they are looking to get rid of. He's sending me pictures and I'll be putting it in the forum if it's a good enough deal I may grab it.
P.S. to a previous post I have a Viper 350 already waiting to go in and brand new top, headliner, rear window and cables
after everything else is set and the car is moving.
Thanks again guys for all the comments and support need any help or info let me know
R32 GTR wheels on with the powdercoated 300zx 30mm aluminum brakes with Brembo OEM rotors
Just got my new tires put on, the 225/55 16 that were on the GTR wheels rubbed because they are
8in's wide and the very corner of the tire hit the back towards the door,so I threw on some Maxxis V-1 225/45 16
and they work really well. Not to mention they look wicked nice on the car.
By the way I am starting to sell off un-used and leftover parts here is the first link and if you
are interested in anything that I may be getting rid of just PM me
rb26dett-240sx-vert-build-leftovers-part-1-t494215.html
Thanks guys I will be at the 240sxmotoring show in july if anyone wants a close up
Finally almost done
All that is left are the radiator hoses and the S14 ebrake cables and then it's the first start up and lots of system
and setup testing. I dont have much for pictures right now but I'll have alot to throw up once it's done and I will
get some videos up on youtube also.
Here are some pics of the mounts with the skyline motor mounts and Syko mounts.
Also the greddy oil filter and cooler block adaptor setup
Huge 30.5mm Tanabe Sway bar, Modifyed oil pan, Kics magnetic drain plug
Other side with the mounts, turbo lines so on
GTR Wheels, 300ZX 30MM brakes and Volk Lug nuts in all their glory
And the nasty Blitz Nur spec Exhaust
Thanks guys
and let me know what you think
The next pictures I'll have will be the motor with all the carbon fiber and everything complete
Here it is, dropped off the Samco RB25DET Radiator hoses and checked the fitment and they need alittle trimmiing like
others have said but they will fit near perfectly. Waiting on ebrake cables and breather hoses.
