Is your rear end all stock except for the J30 LSD? If it is, I will feel alot better about my car at the track on Mickeys in the future.HxC_Nismo wrote:well my best trap speed with my car was 111mph at gateway in st.louis, but anyways im running a j30 diff in my car wich is 3.92 gear ration instead of the stock 4.08 gear ratio and i was cutting 1.8 60ft times and i dont have a two step on my car so i just pretty much brake boost off the line at 7 psi and that around 4500 rpm and i was on bfg drag radials. but i was pretty happy with this time, this was the 3rd time i brought my car to the track and every time before this i ran in the low 13's with 2.1 60fts w/o brake boosting off the line. but im going to get the gizzmo launch interface two step and that should help me get out of the whole alot harder. my buddys s13 with stock rb26 ran a 12.8 with his car but theres room for improvement ill get some more track time when i get my two step. oh and i almost forgot im a pretty big guy so thats also a factor lol.
His times are pretty good actually. There is no way in hell he is going to cut a 1.5-1.6 on those DR's. Not all DR's are created equal; size and compound play a big role and those are not going much harder off the line than what he is at. Maybe if he was on some tall and wide E/T Streets he'd have a chance at a 60 foot like that, BFGs do not equal M/Ts.rb25drag wrote:Well you should get alot better times, Wat kind of boost are you running topend?
I would think you could get at least a 1.5 60' on drag radials, Especially with boost off the line.
Good luck on your times, Give an update when you go back and run it.
yea at this years last midnight madness with my gizzmo launch interface and mickey thompson DR's i had my 2step set at 5400rpm and i was able to build about 3psi of boost off the line but once the light turned green i dumped the clutch and got 100% traction with 15psi in my DR's and i Snapped my weak 6 bolt rear driver side axle and was stuck in st. louis for another day. but i have swapped to the z32 n/a 4.08 diff and 5 bolt axles from my 6 bolt j30 diff. so i have to wait till next season before i can attempt it again. but i should of cut at least a 1.6-1.7 60ft if i didnt break an axle and probaly would of ran a 12.2-12.4 et is my guess. but i should hopefully hit 12.0 et with the 4.08 gears and gizzmo launch interface next season hopefully i will be tuning my car in the spring and should get about 375-400rwhp after tuning on the dynofast_s14 wrote:hey Hans, any updates on times from gateway?
he's running nitto drag radials and cut a 1.8 60ft with speed cut on his r32 rb26 s13. plus when i first ran my car i ran a crappy 14.8 with like a 2.4 60ft dont worry you will get into the 12's but once you hit the 12's you will know when you launch that you'll break the 12's cause your going to need to cut at least a 1.9 60ft to break the 12's in a stock rb26 s14 but to let you all know the MICKEY THOMPSON drag raidials hook the best compared to bfg dr's and nitto dr's. good luck manIndolent wrote:
Hey Hans, your friend with that ran the 12.8 at what psi? tires did he use?
HxC_Nismo wrote:yea at this years last midnight madness with my gizzmo launch interface and mickey thompson DR's i had my 2step set at 5400rpm and i was able to build about 3psi of boost off the line but once the light turned green i dumped the clutch and got 100% traction with 15psi in my DR's and i Snapped my weak 6 bolt rear driver side axle and was stuck in st. louis for another day. but i have swapped to the z32 n/a 4.08 diff and 5 bolt axles from my 6 bolt j30 diff. so i have to wait till next season before i can attempt it again. but i should of cut at least a 1.6-1.7 60ft if i didnt break an axle and probaly would of ran a 12.2-12.4 et is my guess. but i should hopefully hit 12.0 et with the 4.08 gears and gizzmo launch interface next season hopefully i will be tuning my car in the spring and should get about 375-400rwhp after tuning on the dyno
well i swapped over the the z32 n/a diff wich bolts right up to the s14 and has the same leangth snout as an s14 open diff, but it comes with heat sink rear cover and uses stronger 5 bolt axles instead of the weak 6 bolt but its pretty much the same thing as the r33 gts diff but has a more oil capacity rear cover. and i just used 5 bolt axles from a 92-94 j30heres the pics of it installed on my carheres a pic of the 6 bolt j30 next to the 5 bolt 300zx n/a diffbut the junk yard i bought the axles from i might just pic up the diff from them also in case i want the 3.92 gears again im going to see how much of a gain i get at the track before i swap back to a j30Darius wrote:That is what the gizzmo launch interface is for. It keeps your revs from spiking when the clutch is depressed. So you just mash the pedal and keep it there when you shift so you don't lose boost. The exhaust will pop like a bastard between shifts, but who cares. It is definitely on my christmas list.
Hey Hans, why did you swap from a J30 to an N/A 300zx diff? I thought they had different housings with the J30 just being a bit longer due to the ABS sensor on the snout. Did you do it for the higher gearing?
Modified by Darius at 8:35 AM 11/27/2007
